ITB intake
Rebeltaz83
I hate to start a new thread if this has been covered and talked about, I did search but I may not have used the right “key words”. I am curious and I’m sure it has been done, an ITB (individual throttle body) intake setup. And a rough estimate on funds to make it work. I’m sure it’s going to be one of those things that’s not worth it unless I’m racing, or whatever or other intake manifolds, designs. Curious to see what is out there for these V10s without searching the dark cobwebbed corners of the internet lol.
The Gen III/Lambo Intake is a sexy design. Is it a good Manifold? Fine, but not great.
Porting the Gen III just seesaws torque and horsepower numbers and provides limited results. Extrude Honing...about the same.
A front-mounted E.F.I. Throttle Body style Injection setup would have all kinds of distribution issues on such a long Intake. One for each cylinder wouldn't be practical.
I sent a GEN III Intake to Wilson for modification and although they rarely reject a chance to modify one, they did reject it.
Instead, 13 grand would buy a brand new design which leaned heavily toward racing. Because that's what they do (and do very well).
3 other companies were also contacted and came back with largely the same result.
We had interesting results with the Gen II Intake on a Gen III. It provided a boost of 50 lbs./ft. of torque in a narrow r.p.m. range but NO horsepower increase. That Intake is too ugly for me and looked like it belonged on an Industrial application, like maybe a boat(?) My opinion...
I.O.W. limited options. If you know someone that understands airflow and happens to have a large enough 3D Printer, possibilities are endless!
Let me know if you have any luck elsewhere.
I wonder if a duel TBI down draft style would work better? One TBI for each bank(basically like the 8.0L only down draft) intake runners would be different length though. Or a front and rear setup for the back 5 and front 5. I think you would get more power with a down draft than a front…. Then we actually utilize the ram air induction on the hood without having a bunch of duct work. Just thoughts. I don’t know anybody with a 3D printer that understands air flow. If the 8.3 was more in demand I think the R&D would be worth it, unless it’s in the racing world, I don’t see the justification of the cost of such an intake for street use unfortunately.
If you tape some lightweight ribbon in front of the factory hood scoop and go for a highway drive, they rarely point toward it. Because it just isn't a high pressure area and is quite turbulent. Nothing fancy required for equipment as you can see the ribbons blow straight up or are pointing straight ahead. It's not a great spot for the hope of "Ram Air".
The flat front grille and the opening for the o.e.m. airbox on the passenger side does a better job of promoting airflow into the Intake system and simply works.
Put your hand on the front of the Intake immediately after a drive. It is considerably cooler than the back if the Intake. The o.e.m. setup works and doesn't draw in warm underhood air like some "cold air" kits.
That hood "scoop" does help to bail out engine heat at low speeds and when stopped though.
Yes, our Gen III has been out of production for 20 years and was limited production anyway. A worthwhile new Intake design would also be limited production (of course), and still costly.
You'd see vacuum at w.o.t. (particularly if used with high-flowing heads), if the o.e.m. Manifold was leaning towards restrictive.
Distribution is decent and it supports reasonably high horsepower levels without forced induction; so it's not all that bad!
As with many parts though, it can be improved with enough time and money. It all depends on power goals and application.
The flat front grille and the opening for the o.e.m. airbox on the passenger side does a better job.
Put your hand on the front of the Intake immediately after a drive. It is considerably cooler than the back if the Intake. The o.e.m. setup works and doesn't draw in warm underhood air.
That hood "scoop" does help to bail out engine heat and low speeds and when stopped though.
Yes, our Gen III has been out of production for 20 years and was limited production anyway. A worthwhile new design would also be limited production and still costly.
You'd see restriction via vacuum at w.o.t. with high-flowing heads if the o.e.m. Manifold was terrible. As with many parts, they can be improved with enough time and money.
Remember years ago SILVERBACK did a test on the airodynamics and the hoodscoop intake and found just what Ronnie stated ,, the thread should be on here somewhere … Its one of the things that made me wonder about the Volant air intake system and kept me from getting one way back them … Looks cool but needs to be fully functioal as a Ram air intake ..
Yes he did a full test I'll see if it's on here somewhere .... I'm not going to look through all these threads but these are threads he posted in so could be good info in some of these
Close enough to the thread if someone is interested in search through a few ..
Cowl induction is where it’s at…. I don’t have a stock hood. “Ultra violent” is the truck I got so lucky to get my hands on. The OG builder is on this forum but has been inactive for awhile. I would love to find out if anything has been done to the internals on this thing. Top end, cam build, bottom end. It has an aftermarket clutch installed, under drive, JTS TB. It’s been to Scotty in Texas to get his killer side pipe exhaust installed (sounds amazing!) Ugh, I’m drifting off topic… down draft style intake with cowel induction. Six pack style filter setup with a hood mounted air box to seal it off from the engine bay air, and funnel it to the cowl. Lots of info on this forum. It looked like it was super active when these trucks came out, wished I was around on here then. Just graduating high school and enlisted in the army starting my life no way I could afford one these new. Been turning wrenches on anything with an engine since I was 10. Started in a body shop at 15, still doing it just graduated to bigger engines and bigger machines. Mostly diesel now and engines the size of our trucks haha.
Yeah back when this forum began it rocked like no other .. Sounds like you’re on the move with your life in a good way !
Im old school and started at 16 with my first car , became a mechanic and did all kinds of mods . Always a been Mopar guy .. the Trucks were expensive when they came out but now look at just normal ma and pa vehicles prices not to mention the so called highend perfomance cost ..
There have been a few on here with modified hods with more of a sealed air intake .. again searching threads , the media picks might turn those up .. I know one was a yellow fever and it may have Been @HemiLonestar post something up similar not that long ago .. Im sure he will chime in … others have modified the factory air intakes which appear to be sealed more to the outside air at the grill and avoid the hot as hell underhood heat ..
@Wifey might find a thread if she searches ,she’s excellent at finding old threads ;)
You could also check the JTSVP fiberglass hoods the made and maybe still doing them …
This could be the JTSVP HOOD ,, There was another vendor that produced hood’s also but can’t remember who it was …
Holley Engineering released an excellent book a few decades ago which touched on the topic of Ram Air. And of course, years later, the math is still valid...
AT BEST, a properly designed and sealed ram-air system only produces ONE QUARTER OF ONE P.S.I. at 200 km./hr. (124 m p.h.) at sea level. That equates to an approximate 0.83% boost in power.
Put in perspective, there is a full THREE P.S.I. increase simply driving from say Calgary (3800 feet), to sea-level. Or.. quick math: a whopping 12 times the effect of the best Ram Air setup.
That simple drop in elevation is a 10% increase in power, in this example. For my truck, that's approaching 80 horsepower.
Compare Ram Air system gains to the solid 14 horsepower provided by a drop-in air filter and an underdrive pulley.
Just sayin'...
Holley Engineering released an excellent book a few decades ago which touched on this topic. And of course, the math is still valid...
AT BEST, a properly designed and sealed scoop may produce ONE QUARTER OF ONE P.S.I. at 200 km./hr. (124 m p.h.)
Put in perspective, there is a full THREE P.S.I. increase simply driving from say Calgary (3800 feet), to sea-level. Or.. quick math: a whopping 12 times the effect of the best ram air setup.
Another way to look at the result of a GOOD ram-air system would be a 0.83% horsepower increase at sea-level at 124 m.p.h.
Just sayin'...
What if you added one of those turbo fans into intake tube .. could we get the .83% up to a full 1% hahahaha
Hahaha!
The medium to large sized fans at the majority of dyno facilities don't even come close to simulating air pressures at road speeds. They help for cooling but fall way short providing pressures across the whole vehicle surface as seen out on the road.
So the tests you see for performance air filters (a.k.a. warm air kits), with a big square fan from COSTCO blowing on the front grille isn't doing anything.
Gale Banks (turbo guru, among other things) uses some pretty serious air power in his dyno facility during testing such things for a reason.
Yeah, but then you'd be popping wheelies...
Sounds like something everyone would have fun doing .May also help with the aerodynamics drag and cooling efficiency …. Hence faster trap speeds and cooler outside intake air charge .. heck add one to the rear of the truck to help propel it like a rocket hahahah
