What has been done to the oil system that improves and control the oil in the engine ..
Wet sump type ! windage trays , dual pickups, pumps channels/ ports , etc .. Ive never torn down the viper motor and wondering if improvements can be made, Should or have been done ?
The truck engine uses a nice deep sump and that's a plus, for starters.
My own engine oiling mods:
The oil pump relief spring (GEN III) used a 3-piece which was prone to oscillating so I went with a single. The good upgrade is to use the GEN IV style main bearing setup. This allows more oil between the bearing and crank interface. It also required machining little "bathtubs" in the block main saddles to take advantage of the newer style bearings.
I left the oil scraper installed. And a few oiling passages were rounded a touch with a high-speed bit.
The pisser is having to drop the pan on a Gen III and unbolting the pickup tube along the bottom of the block BEFORE trying to remove the timing chain cover. This for a cam change, for example.
My own engine buzzed freely to 7,000 on the engine dyno without any signs of starvation.
It won't do 7K with the 48RE though with the o.e.m. electronics, but doesn't need to either!!
The oiling system seems robust as I've had it apart a more than a few times and other Viper engines as well and none had any hints of oiling issues.
The only thing now is with the new style bearings and single relief spring, the pressure is higher than needed, even with 0-30 and its likely using up 35-40 horsepower, if not more. So...that will be remedied!
Besides, one of the pesky SRT RumbleTundras might show up in our area!!
Some Viper engines that came around had even taken themselves apart, without tools !!
A supercharged truck comes to mind. Detonation took out a crown, the piston layed over, jammed in the cylinder and then the rod punched a hole in the block. It was very anxious to get out of there!
