My catch can never did anything before the motor build and now it gets 1/2 full in 500 miles. But there is a lot of oil floating around in rocker covers. When I change over to synthetic oil, it will be interesting if it changes. Also changing to thinner oil as I still have 80lb at 2500rpm when oil is 180 temp. So the Boundary Racing pump maybe a little overkill. Probably wasting hp too.Folks on the Internet were all over the idea of putting a "catch can," on their modern Mopars some years ago. I did a bunch of research and chose a really expensive one (for what it is). Next oil change I was greeted with maybe a tablespoon of oily water vapor condensate. Made it sound like all these things were oil burners and my throttle body was guaranteed to be carbon'd and grubbed up if I didn't install one.
Pulled it back off and it's been in a box ever since.
Small (regular size) or Jumbo 32 Oz. Catch Can?My catch can never did anything before the motor build and now it gets 1/2 full in 500 miles. But there is a lot of oil floating around in rocker covers. When I change over to synthetic oil, it will be interesting if it changes. Also changing to thinner oil as I still have 80lb at 2500rpm when oil is 180 temp. So the Boundary Racing pump maybe a little overkill. Probably wasting hp too.
The hoses are routed a long way .. to what connections ?View attachment 70478
It works.
The intake is dry
It certainly hoovered up a lot less when I put the restrictor in the line.
