2/5" lowering kit
ViperPete
Ocala, FL
hey all
About 80% done installing the urethane everything and 2/5" lowering kit
How much material do I have to remove from the front sway bar end links? I have heard an inch to an inch and a half.
Also,
Does anyone have detailed instructions on how to install the belltech rear swaybar? Like where to drill and ect?
Want to finish tonight!
thanks!
I think jmb has the proper end links instead of cutting yours, not sure on the sway bar though.
Do you need to cut the end links after doing the 2/5 drop
Yes,
In order for the sway bars to function correctly the ends need to be parallel with the ground. With a lowering kit they stick upward and are not effective.
Yes,
i ran for a couple weeks after lowering my truck before correcting the end links. I didnt realize i need to fix them at first, slipped my mind. And what a difference it makes when you have the correct end links length :rock:
