Installed overhead console this morning .. CHEAP ASK PLASTIC , factory mounting screws were loose also ..
I took all precautions from reasearching and only broke off the wire connector mounting tab trying to unplug it . (Cheap brittle and broke off by breathing on it hahaha ). I removeed the back body clips and screws and discarded those using the factory clips still installed .. when reading and reasearching reviews , many complained about removing or installing the lenses would break the hold on tabs .. ( yeah they just didnt pay attention and all those reviews was due to their mess up IMO . ( I hate reviews ) the lenses must be installed on the proper side .. they must be removed using a small flathead and lightly pop off the lens near the hold on clip side .. Installing the lenses doesnt take a hammer just a simple light push and click in they must be start buy putting the back end in first .. ( checking that the hold on clips are in line with the tabs ) .
You will have to remove the digital unit and reinstall it into the new cover ( un screw it before disconnecting the wire connector )
Be careful when reintalling the digital unit that all 4 screws line up properly each time you put a srew in ) they are small so dont drop and loose them hahaha .. dont over tighten .. takes about 20 minutes ... simple if you pay attention !
New one matches color perfect , LEDs working great ....
View attachment 68829View attachment 68830
View attachment 68831View attachment 68832
