AHR long tubes install issue
Discussion in 'Performance Mods' started by Longshot, Sep 14, 2020.
  1. Longshot
    Longshot New Member
    26
    19
    Oct 14, 2019
    I just installed some ARH long tubes and one of the headers is touching the trans. I used Mopar MLS gaskets. Anyone else have this problem? I wasn't able to move the pipes to get clearance. I can push the pipes and they will bend away. Should I try harder to lift the rear of the pipe for clearance? Different gasket? Should I put a piece of high temp silicone hose there? I guess I could grind it down a bit. I'm kinda bummed I have to mess with it to make it work
  2. V10Brian
    V10Brian New Member
    6
    3
    Mar 2, 2020
    I have used 1.5" Home Depot Ratchet Tie Downs to bend my long tube stainless headers.
    Stainless is kind of soft, so if you don't have stainless, it might not work.
  3. oldcolt
    2,731
    83
    Jul 14, 2008
    Calgary, AB
    It's not unusual to have to finesse headers into place. Use straps to bend them away a bit.
  4. Longshot
    Longshot New Member
    26
    19
    Oct 14, 2019
    Thanks, I didn't know that. I put in a very slightly thicker gasket and filed down the trans a little. I'm about to torque it down and see. I'm wondering how much clearance I need there.
  5. rottenronnie
    3,588
    1,058
    Jul 4, 2006
    Calgary, Alberta
    Yes, even in 2020 it seems that fabricating a header that simply bolts up is a challenge. Mine took a ratchet strap and a bolt extender to twist the flange into position. Shouldn't be that way on a pair of headers that were $2795.
    After a few hot/cold cycles they DO relax into position.
    AMS3 likes this.
  6. Longshot
    Longshot New Member
    26
    19
    Oct 14, 2019
    I got my pipes used from a salvage yard for 800. It took a lot of work to get them shine again. The idiot that had them before me had the right side welded to 3" steel and the left 2.5", lol. It was a little challenging to tig a 304 vband to it but it turned out nice...I did green cats and I've got some moroso spirals to try out. It's going into my old magnaflos.
    AMS3 and Srt10650 like this.
