I was thinking along the same lines as Silverback...you do need something to keep the oil circulating to maximize cooling but maybe the fan blades are enough...but there has to be a shortening of the life of the fan motor due to the resistance...
Prof said:I was thinking along the same lines as Silverback...you do need something to keep the oil circulating to maximize cooling but maybe the fan blades are enough...but there has to be a shortening of the life of the fan motor due to the resistance...
You know...Prof said:Scott...do it...give us a DIY!
RatMotor said:http://www.tomshardware.com/2006/01/09/strip_out_the_fans/
Tom's Hardware did a similar build a while back, looks like didn't submerge their power supply though. Pretty damn interesting article, although I think the possibility of a catastrophic leak will keep me from ever trying it. I'm still a bit uncomfortable with the small liquid cooling system I have now.
They used an older single core AMD FX55 at 2.6 ghz, temp maxed out at 104F - 8 gallons of oil with no means of circulation. I'd like to a see how a newer dual or quad core overclocked would do with some kind of circulation or radiator system.
Silverback said:Are you speaking english????:dontknow:
Manic said:Here is a liquid cool system that :rock:!
Will
RatMotor said:Very clean, right now only my CPU is liquid cooled, and it's an external pump/reservoir/radiator. Next time I build a new comp I will go with an integrated system like that:rock:
Prof said:The fans on my cpu are really noisy, have been from day one. This approach would certainly solve that issue..
