Back firing in intake when accelerating under load
Discussion in 'General Discussion' started by 500H V10, Nov 10, 2023.
Car Parts
  1. 500H V10
    500H V10 Full Access Member
    180
    13
    May 20, 2006
    Chillicothe, Missouri.
    I'm not sure what's causing this there is no codes present but back firing inside intake when accelerating under load
    Wifey likes this.
  2. Michael from the U.K.
    Michael from the U.K. Active Member Supporting Member
    352
    42
    May 22, 2006
    Berkshire in England
    I had that one time,I think my harmonic balancer was dodgy,not sure tho but it was something like that.
    Wifey likes this.
  3. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    Do a leakdown test (not just a simple compression test) to isolate a cylinder that may have a leaky valve.
    If all the cylinders are holding air (passed the leakdown test), then a leaky injector or an ignition issue (coil or plug) is next on the list.
    AMS3, THEWELSHM, 500H V10 and 2 others like this.
  4. VIPR PWR
    VIPR PWR Full Access Member
    5,432
    749
    Jun 12, 2007
    FL
    Did you do any work on the truck ? Plug wires crossed , burnt ?
    500H V10, Wifey and rottenronnie like this.
  5. 500H V10
    180
    13
    May 20, 2006
    I'm thinking of checking the fuel rail pressure though maybe my fuel pump starting to go I would think I would get a code though if it was low fuel pressure. Everything is untouched.
    Wifey likes this.
  6. 500H V10
    180
    13
    May 20, 2006
    The engine idols very smooth and under light acceleration it runs very smooth with no misfire only under heavy acceleration does it randomly backfire in the intake manifold
    Wifey and VIPR PWR like this.
  7. VIPR PWR
    5,432
    749
    Jun 12, 2007
    FL
    Intermittent misfire .. possibly weak or damaged plug or plug wire . I know I had a plug the the electro was bent and off center and cause it to intermittently misfire on mid range acceleration . Plug wire break down in high temperatures or get burned from the exhaust and can send spark to a ground area it’s close to or touching .. try opening the hood in the dark ,, no lights around and see if there is any arcing from the plug wires or coil packs . when my plug was misfiring I did get a code though !
    eliminate the easy stuff then move on to the next . Some of the problems that cause that stink ..
    500H V10 and Wifey like this.
  8. 500H V10
    180
    13
    May 20, 2006
    I'll check under the hood later tonight for any arcing. Thanks!
  9. VIPR PWR
    5,432
    749
    Jun 12, 2007
    FL
    You can also check using an ohm meter on each plug wire to see if any are broken down on the inside .. yes the wires are a pain in the butt to get to under the intake manifold .
    Why the hell did they put the coils there . Still nobody that I know of has relocated the coil packs out from under the manifold ..
    THEWELSHM, 500H V10 and Wifey like this.
  10. Michael from the U.K.
    352
    42
    May 22, 2006
    More fun for us if you put your hand on the wires tho.:D
    Wifey likes this.
  11. VIPR PWR
    5,432
    749
    Jun 12, 2007
    FL
    Hahaha ,, helps you bounce a bit doing that …
    In the old days with customers hanging on the fenders while we worked on cars ,, we always kept a charge ignition condenser sitting on the fender cover .. if they got to nosey we asked them to hand it to us hahahaha ZAP !
    years ago I wanted to test out the sparking of my new MSD ignition system .. supposedly fired like 20 times per cylinder revolution .. I believe they were right hahaha ZAP ZAP ZAP ZAP at 40k volts per ZAP hahah
    Michael from the U.K. and Wifey like this.
  12. Wifey
    Wifey Well-Known Member
    23,577
    660
    May 18, 2006
    To funny!
    VIPR PWR likes this.
  13. THEWELSHM
    THEWELSHM Well-Known Member Supporting Member
    2,454
    72
    Aug 29, 2008
    Brandon Florida
    seen my coil packs 3 times in 3 months, hope I don't see them again for a while. those back inlet bolts suck to get at.
    thewelshm
    VIPR PWR, Wifey and rottenronnie like this.
  14. VIPR PWR
    5,432
    749
    Jun 12, 2007
    FL
    I’ve heard and read that .. I’ve never had to or even wanted to pull the damn intake ,,,,Stupidest design I’ve ever seen .
    Wifey likes this.
  15. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    The adventure really begins when you strip the upper Intake bolt on #9.
    THEWELSHM, VIPR PWR and Wifey like this.
  16. VIPR PWR
    5,432
    749
    Jun 12, 2007
    FL
    :eek: That can’t be fun
    Wifey likes this.
  17. Wifey
    23,577
    660
    May 18, 2006
    Try it ??? :p
  18. VIPR PWR
    5,432
    749
    Jun 12, 2007
    FL
    I’ll send the truck to you and you can move my coils to a easy access location :p:D
    Wifey likes this.
  19. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    There is only one bolt that is a bit of a challenge when removing the Intake (#9).
    Like everything, once you've done it a few times, there are tips and tricks to make the job easier/faster.
    I'm still wondering how grasshoppers and bees (well, what's left of them) end up behind the coil packs.
  20. Wifey
    23,577
    660
    May 18, 2006
    Bees are amazingly resilient!!
