Back firing in intake when accelerating under load
Discussion in 'General Discussion' started by 500H V10, Nov 10, 2023.
Car Parts
  1. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    Honey Bees hang around flowers all day and live life free and easy.
    The downside is they can sting only once, their asses pull off, and they die.
    Bumble Bees however are risk-takers and are better equipped to fight.
    They can keep stinging repeatedly without penalty, BUT may end up taking a rapid trip through the grille of oncoming vehicles or a similar fate due to their reckless behaviour.
    So...Is it best to play it safe and risk losing your ass, or take risks and have fun during the ride?
    My thought for the day...
    Ronnie
    THE END :)
    Wifey likes this.
  2. THEWELSHM
    THEWELSHM Well-Known Member Supporting Member
    2,454
    72
    Aug 29, 2008
    Brandon Florida
    I have a couple of ground edge deep well sockets that work pretty good on those back ones, in 11mm and 7/16"
    thewelshm
    Wifey likes this.
  3. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    I tried a few things but the intake manifold casting was in the way. I ended up filling a socket with JB Weld and leaving it on the stripped bolt overnight.
    Fortunately, it came out.
    VIPR PWR and Wifey like this.
  4. Wifey
    Wifey Well-Known Member
    23,588
    668
    May 18, 2006
    Hahahaha! Right!
    VIPR PWR likes this.
  5. VIPR PWR
    VIPR PWR Full Access Member
    5,442
    763
    Jun 12, 2007
    FL
    Hahaha ,, It must be the bees wax on , bees wax off Danielson grasshoppers hahaha ..
    Wifey and rottenronnie like this.
  6. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    Thinking out of the box helps sometimes .. or luck was on your side . I’ll have to remember that one if it ever happens to me !
    Wifey likes this.
  7. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    I could have pulled one head and taken the Intake with it but it seemed like a lot of extra work at the time.
    I used some Brake Clean on the bolt and socket first, so the JB had a good surface to grip.
    The socket was a gonner packed with the stuff, but it was a cheap solution that worked.
    Yes, some luck for sure!
    Wifey and VIPR PWR like this.
  8. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    More the reason to relocated the coil packs to an easy access location IMO .
    Wifey likes this.
  9. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    But then you'd lose that sexy vintage Lambo' engine look!
    THEWELSHM, VIPR PWR and Wifey like this.
  10. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    I’m sure someone could come up with moving the coils and still keep the sexy in it … Anyone willing to take the plunge ? Hint hint :D
    Wifey likes this.
  11. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    On Doms truck what is his coil set up .. looks like each plug has its own .. if im not mistaken doesnt the gen 4 vipers have that kind of setup ?
    Wifey likes this.
  12. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    Aftermarket systems are available for a coil per cylinder setup if you wanted to go that route.
    I've never been a fan of aftermarket ECUs for a daily driver. They just aren't as robust as the factory stuff, in my experience.
    Switching an existing OEM system over to our engines is beyond my level of expertise.
    I will just have to spend the time to pull the Intake to change plug wires and coils, as needed.
    I've had mine on and off so many times, it's really not a hassle. Until I stripped that difficult to get at bolt on number 9 !!
  13. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    505H V10 ……. Any progress on finding the problem ?
    Wifey likes this.
  14. 500H V10
    500H V10 Full Access Member
    180
    13
    May 20, 2006
    Chillicothe, Missouri.
    Sorry for the delays I'm getting over a bad cold.
  15. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    Apologies not needed hahaha . Just get over that cold and get back to the truck .. 10’s need ever loving care ! :D
    Wifey likes this.
  16. Wifey
    23,588
    668
    May 18, 2006
    :) Yes, get yourself well!! That's what matters most
  17. 500H V10
    180
    13
    May 20, 2006
    Thank you guys! Happy Thanksgiving!!!
  18. 500H V10
    180
    13
    May 20, 2006
    Oh what a difference a day makes !!!
    Chillicothe Missouri.
  19. VIPR PWR
    5,442
    763
    Jun 12, 2007
    FL
    Damn that’s one bad case of dandruff :eek: I haven’t seen snow in decades hahaha
    Wifey likes this.
