Battery relocate Kit (NEED PHOTOS)
OSO
Houston/ Northshore
Just trying to get an idea of what i need to modify . If you can post pics i would appreciate it.
i think JBM justin sells a kit with a battery tray
Yes, however that doesn't answer my question. looking for pics of one installed or info on what had to be modified.
Its official Coley is slow and i am not talking about his truck:D
But Coley "BEE" the illest..
TNVIPER said:
So easy even a Hemi owner can do it...:D ........I have justin's kit..easy to do if you have a lift but not required..
Did you leave every thing else in place abs controller battery tray fuse box. I plan on relocating all of it ?
if you search or click on the jmb forum you will find all the products he has sold and the write ups +pics on every product...
FerrariTruck said:
if you search or click on the forum jmb you will find all the products he has sold and the write ups +pics on every product...
You're making too much sense, stop it;)
I am most of the way through relocating all of what you are talking about. The lines for the abs controller will be the hardest part. There are no fittings available that can adapt so that stainless braided lines can be used. I have searched everywhere and Stinker had sent me some fittings to try out and it cannot be done. The original lines have to be cut and the original line nuts be used on new bent lines. I mounted my abs controller under the drivers side on the frame rail and extended the wiring harness to it. Its a fair bit of work but damn it looks way better. I also relocated the fuse panel too.
Do you know if the abs controller has to stay flat or can it be mounted on its side?
This I do not know. I mounted mine at the same level as it was in the original location, except the lines pointing forwards.
I'm moving the fuse panel inside and wanted to move the abs controller to the fire wall. Guess i can always try it and see if it still stops:)
