OSO
Just trying to get an idea of what i need to modify . If you can post pics i would appreciate it.
i think JBM justin sells a kit with a battery trayOSO said:Just trying to get an idea of what i need to modify . If you can post pics i would appreciate it.
Yes, however that doesn't answer my question. looking for pics of one installed or info on what had to be modified.Coley 1334 said:i think JBM justin sells a kit with a battery tray
OSO said:Yes, however that doesn't answer my question. looking for pics of one installed or info on what had to be modified.
Its official Coley is slow and i am not talking about his truck![]()
You wouldn't lie to me would you if you are tell me its the biggest you ever had505'sFastestViper. said:uh nothin has to be modified its plug and play
its not only the biggest its the best!!!!!!OSO said:You wouldn't lie to me would you if you are tell me its the biggest you ever had![]()
Did you leave every thing else in place abs controller battery tray fuse box. I plan on relocating all of it ?TNVIPER said:So easy even a Hemi owner can do it...........I have justin's kit..easy to do if you have a lift but not required..
FerrariTruck said:if you search or click on the forum jmb you will find all the products he has sold and the write ups +pics on every product...
OSO said:Had to go back to 07 but found what i was looking for!
Oh now somebody puts the link up!FerrariTruck said:
OSO said:Did you leave every thing else in place abs controller battery tray fuse box. I plan on relocating all of it ?
Do you know if the abs controller has to stay flat or can it be mounted on its side?yellowfever#154 said:I am most of the way through relocating all of what you are talking about. The lines for the abs controller will be the hardest part. There are no fittings available that can adapt so that stainless braided lines can be used. I have searched everywhere and Stinker had sent me some fittings to try out and it cannot be done. The original lines have to be cut and the original line nuts be used on new bent lines. I mounted my abs controller under the drivers side on the frame rail and extended the wiring harness to it. Its a fair bit of work but damn it looks way better. I also relocated the fuse panel too.
OSO said:Do you know if the abs controller has to stay flat or can it be mounted on its side?
I'm moving the fuse panel inside and wanted to move the abs controller to the fire wall. Guess i can always try it and see if it still stopsyellowfever#154 said:This I do not know. I mounted mine at the same level as it was in the original location, except the lines pointing forwards.
