Big Thanks to SRT2SLOW
Discussion in 'Visual Mods' started by outnumbered, Mar 29, 2014.
  1. outnumbered
    outnumbered Active Member Supporting Member
    3,128
    For helping me get my new HID's squared away. Headlights and fogs will now give the sun some competition.
  2. Privatetoe82
    Privatetoe82 Full Access Member
    602
    Apr 1, 2013
    Glenside, pa
    I still gota do my fogs.
    Sent from my SCH-I545 using Tapatalk
  3. outnumbered
    3,128
  4. VenomTruck
    VenomTruck Full Access Member
    3,337
    May 13, 2012
    Columbia SC
    Looks good Ron, did you mount your ballast in the same spots I did?
  5. tdamon30
    tdamon30 New Member Supporting Member
    102
    Sep 16, 2011
    Lake City, FL
    I miss my HID's. I couldn't get them working correctly with the OEM headlamp switch. I tried relay harness and the caps/resistors, they would just blink on and off. I rigged a separate on/off switch for them but that was too cumbersome so I removed them :(
  6. VenomTruck
    3,337
    May 13, 2012
    Columbia SC
    Love my HIDs, Ill never go back to halogen.
    [​IMG]
  7. outnumbered
    3,128
    I think very similar
  8. outnumbered
    3,128
    I think E has been using this particular company for a couple of years without issue. I think the trick is to go cheaper in order to get a system that works.
  9. ViperPete
    ViperPete Full Access Member
    2,659
    15
    Aug 4, 2010
    Ocala, FL
    What did that system run you?
  10. outnumbered
    3,128
    For the headlights <$100
  11. ltnate3
    ltnate3 Full Access Member
    231
    5
    Nov 26, 2012
    Louisville, KY
    Is there some kind of "trick" to proper headlight adjustment? I installed HIDs too but I have no idea if I lined them up right.
  12. outnumbered
    3,128
    If you have the OEM style, the casing does have adjustment rods
  13. VenomTruck
    3,337
    May 13, 2012
    Columbia SC
    Should be adjustment screws that moves the entire housing just like most other cars. Locate the screws and then go point your truck at a brick wall or garage door at night and line the beams up.
  14. ViperPete
    2,659
    15
    Aug 4, 2010
    Ocala, FL
    I've got a brand new pair of 2008 Acura TL Bi-Level Xenon projectors and ballast.
    Id love to figure out a way to mount them in the headlight assembly and have badass projectors. Just don't know how to do it- or the time.
  15. ltnate3
    231
    5
    Nov 26, 2012
    Louisville, KY
    Oh yeah I know where the screws are and how to adjust them physically, I was just talking about where the beam should actually be. Is there a certain height at a certain distance I should be aiming for?
  16. outnumbered
    3,128
    Now that I don't know. I go with what create's the best visibility without blinding everyone.
  17. VenomTruck
    3,337
    May 13, 2012
    Columbia SC
    Thats…..thats HOW you adjust the beam… Like I said park about 20 feet away from a garage door, turn on your headlights and have them about waist level and even.
  18. VenomTruck
    3,337
    May 13, 2012
    Columbia SC
    You'd have to bake them and probably modify the inner housing with a dremel, but it would be cool.
  19. ltnate3
    231
    5
    Nov 26, 2012
    Louisville, KY
    Ok that's what I needed...20 ft at waist level. Thanks!!!
  20. VenomTruck
    3,337
    May 13, 2012
    Columbia SC
    [​IMG]
