Now the question that I have is why? I have never ever bent a rod. I have destroyed pistons by over revving, I have yanked skirts off of them, jammed valves through the dome more times than I care to admit (valve float) and I have destroyed rod journals due to too much boost..but never bent a rod...
Can someone tell me the two or three most common reasons that a rod would bend, but the piston not be destroyed??? Seems the piston would be the most fragile part of this process and that they should disintegrate long before a rod would bend....???
The most commom cause for bending a connecting rod is to "hydraulic" the cylinder associated with that rod. Having a high volume of liquid in the cylinder that will not compress. Fuel or water; ie coolant. It can also be done with too high a working cylinder pressure for the rod to handle. Cylinder pressure is what makes HP and torque. That is why a rod has a range in which it will operate safely. Another cause can be the piston sticking in the bore and binding itself to the cyl wall.
In Bone's situation this high cyl pressure appears to be the reason for failure. The rod itself was not up to the task.
The stock rod failed beacuse it was past its design limits. Usually the rod will break close to the big end on a senario with excessive cyl pressure under running high loads. Bent rods are very common in big HP turbo and blower motors.
Bone is very lucky the rod did not break in the middle with catastrophic consequences. As this will uaually "window* the block and pan making the parts scrap.
Pistons are usually destroyed by detonation or excessive heat (high flame front on fuel motors). Detonation shatters the rings and ring lands as well as causing the rod bearing to flake, pound and delaminate.
*"Window the block" is a racers term for knocking a hole in or knocking chunks out of the block, usually caused by a connecting rod breaking.
