Dave, I'm not a tuner by any means, but I do have
slight experience.; and computers is my life, so I've investigated our PCM programming fairly well
The split second is a fairly complex if you create a custom tune via purple wire off the box. Stock it comes as a 3d map using RPM and Vac as its main source of tune. Table A isn't used in these truck from Paxton, but B is used from the pulling of timing, so I'm wondering what your programing numbers are like.
How are your pumps?
is your 'set' pump turning on @ -4 inches of mercury?
is your adjustable turning on @ 1.5?
What are your boost levels, and at what RPM? Do you have your split second program on file? if so, I would like to look at it...
These trucks LOVE boost, and even the slightest amount of boost (3-4psi) will give you incredible amounts of torque due to the displacement. As an example...mine at 3psi which is about 3k rpm, makes over 520tq at the wheels and 300HP and skyrockets from there. I max out at about 7.83psi to be safe, which yields my current results.
Even at 'low boost' you should be putting some decent numbers to the wheels, something definitely isn't right.
Do you have a wideband? if so, what are your numbers @ WOT through the RPM range? Are you suffering with a MAJOR case of heatsoak?..something isn't right, but its hard to diagnose it over the net...
-Red
