Tonkasmith
First want to say Tony, Bobby, and Steve thank you very much for all the help and for answering all of the questions that a newbie would have, even if he shouldn't so with these three gentlemens expertise and advice I am gonna hopefully be pushing 700 whp. With that said here is the build up to now though more is gonna be coming soon
1. Paxton novi 2000 with intercooler and air induction
2. Magnaflow cat back exhaust system
3. Belanger long tube tri-y coated headers and mid pipes
4. Pin fit pistons and rods to size
5. Tear down and inspect cylinder heads
6. Power hone bores to correct surface finish
7. Balance rotating group to aircraft tolerances
8. Glass bead ports and chambers
9. Cylinder head porting stage 3
10. Cut for oversized valves
11. Valve job, multi angle seats and grind valves, equalize valve heights
12. Cut spring pads for 1.437 springs
13. Clean and assemble heads, sct springs etc.
14. Custom forged pistons to specs
15. Wrist pin for application
16. Billet parabolic I-beam pro series connecting rods
17. Custom grind hydraulic roller cam
18. Anti-pump up roller lifters
19. Adjustable timing set
20. High tensile head studs
21. Plasma sprayed moly ring set
22. Premium bi-metal factory performance main bearings
23. Premium bi-metal rod bearings
24. Mopar performance gasket set
25. Coated ml8 head gaskets
26. Shaft mount roller rocker assembly
27. Stainless swirl polished 2.020 intake valve
28. Stainless swirl polished 1.600 exhaust valve
29. Endurance roller spring 1437d
30. Titanium retainers
31. Machined valve locks
32. Valve seals, positive seals
33. Intake gaskets
34. Clean mag, and check for straight
35. Offset, grind, and index crankshaft to 4.000 stroke
36. Ion-nitrate heat treat crankshaft
37. 1/2 inch fuel line
38. Ngk plugs
So when I talked to the shop they told me it was a 545 stroker motor and that the guy who had it built had everything done to it that they offered. Next up supercharger upgrades and like I said thank you Tony, Bobby, and Steve.
33. Intake gaskets
38. Ngk plugs
