RMARRHEMI
the oil can only get into the intake if the valve seals are leaking, but then the intake air pressure should suck it into the combustion chamber and burn it. There should be no oil in the intake.
will it hurt if i put a pcv valve on it?
He us miising the baffles he is runnn strykers with aftermarket rocker which u loose the splash guard i am gonna try to make him a guard to keep the oil from kikin out the ports
He is missing the baffles because he is running stryker brand after-market heads with after-market rocker arms which require removal of the splash guards in the valve covers. I am gonna try to make him a guard to keep the oil from spurting out the ports...
Here is a break down pretty sure after market as well
under the vavle cover, like a spacer?
Have that to of stryker. But it looks like sheet metal type material inside the cover itself. I guess thats the splash plate on the passenger side.
