blackmamba
They also help reduce detonation and if you run two like I do for the reason of being is if I were to have blow by issue I would know what side right away.
That is the best way to do it, a can for each side!
It doesn't determine what side. The crankcase is a common area, no matter what bank is leaking it "should" come out of both cans. But there is a slight variable, the stock barbs or nipples on the valve covers do not have the same orifice size through the barb. Even though they appear the same from the outside, if you remove them you will notice one side is much more closed off than the other (I don't remember which side is which). So when using unmodified valve covers, then yes the vapors may tend to go more to one can than the other due to a restriction at one valve cover. But in a case like your plumbing where we modified the valve covers for the ORB threads, the orifice size is the same therefore allowing the vapors to exit both sides with the same efficiency.
Hopefully that makes sense?
The catch can is a oneway setup... (isnt plumbed back to engine)
