Rice Eater
Can anyone point me to a place that lists all trouble codes? TX!
Roz-SRT said:
RedSrt007 said:its not a fuel hose, its a evap system hose (emmisions). There is a diagram somewhere (ill do a search for it on the forum) that has the route for the evap lines.
It starts @ the gas cap and works its way to the front of the motor. If your under warranty, best way is to have them deal with it and run tests with the drbIII.
-Red
ViperTruck2933 said:How did you check for codes?
I tried turning my key on and off 3 times to see if I have any codes and I didn't see anything, anywhere.:dontknow:
Do the codes show up in the odometer section?
evap. leak, pinched hose.Rice Eater said:Chit.....no more warranty![]()
Red do you think it could cause my cutting out condition?
1qksrt said:Hey Chad
Call me,that code shouldn,t affect driveabilty!
Check all your basics first,PLUGS,Ign. wires and fuel.
When did the you first notice the problem?:dontknow:
You should have a missfire code(po301,302,ETC)
I can talk you through most of the diagnostics:rock:
