Guaging interest in a complete braided brake line kit
This will be complete fronts with minimal modifications
and the rear kit from the frame, to the axle, then to both calipers.
this will give tons more positive feel braking,plus be a little more bling bling for those like Brat
they will be made by goodridge a leading company in brake lines:rock:
I am also working on a new oil cooler line set up, this could be just the lines or a complete new cooler.
The problem with the oem cooler is it works off the engine coolant, the oil is passed thru a cooler with the engine coolant circulated thru the cooler, so if you engine is 200 degrees then you oil will be about the same.
With a separate cooler you can bypass the oem cooler and run a air to air cooler and the oil temps will lower.
I set up a poll to guage interest.
