anthonyraywalter
i have a strong coolant smell coming from my 05 qc, using 1 pint a day! no leaks that i can see. oil is good! i need help please
TNVIPER said:After the motor is hot check the hose that comes out of the filler neck on the radiator....that lil bitch hose has cracked on me 3 times...
If it is leaking more then likely its sitting in the bottom liquid ledge (under the fascia) and then drying. its a good thing for the track but it sucks in way because if your leaking coolant,oil or pwr steering fluid you wont see it unless you look under there.wesalbert said:Does our waterpump have a weep hole? :dontknow: IF so, shouldn't he check it to see if it is wet?
yellowfever#154 said:Go to the local parts store and get a cooling system pressure tester. Pressurize the system and look for leaks.
i think Kevan wrote a DIY for the fix a while agoCruster said:Mine got knocked loose when I was putting in my K&N and when I put it back on I discovered a little crack and the truck only had 5K on it then.
eddie102870 said:i think Kevan wrote a DIY for the fix a while ago
