srt10onfire
Absolutely love my truck!! Bought my 04 RC in 2008 with 7000 miles on it. I only drive it in the summer months and just turned 23000 miles on it now.
Up til the end of last summer it NEVER ran over 200 degrees. I parked it for the winter and now decided two weeks ago to replace the t-stat, so I replaced it with another 185 t-stat. I bled the air out (multiple times) and made sure to top off the fluid. It doesn't matter what the outside temp is, 80 or 45....the temp will run anywhere from 185 to 206ish but fluctuates anywhere in between with no apparent rime or reason. I had a friend plug into the computer to verify that the temp and gauge is reading accurately, which it is, as he did get a high reading of 206.
Could there be a problem with the hydraulic cooling fan causing this to happen?
I've been reading that there is an adjustment that can be made to start and stop the cooling fan at different temps. Could this somehow have changed and should I try adjusting this, and how should I go about doing it????
Any help would be appreciated!!!!!
