Black1 said:Damn, that's pretty cool right there! :rock:
Thanks...ill have to fab up a tube that will route to it for the 10....i'll figure out something
VIPR PWR said:05 ram 1500-------How does yours connect to the filter and the throttle body -----Post up some PICS....
505'sFastestViper. said:![]()
here is my cold air tube it goes where the fog light would be![]()
WOT said:While I agree that our trucks need a good cold air intake, tying to effectively make a ram air is a waste of time. If you were to put a scoop on the very front of the truck, let's say something like an 18" diameter tube that stuck out in front of the radiator, you still wouldn't get much pressurization. Doing some quick calcualations, here are maximum possible obtainable pressures at various speeds. You would have to be traveling over 240 mph to get even 1 psi.
cobraken said:Article in R & T said that the ram air on the new Ferrari picks up 5 hp @ over 200 mph.
what he said.Black1 said:The factory air-box setup is actually pretty good on these trucks. The panel behind the front grill directs air into a channel behind the passenger fender, feeding the inlet to the box. With the addition of a K&N (drop-in) filter, I believe this has shown to produce the most HP. Some, if not all, of the "CAI" units actually LOOSE power.... but, they sure do look purdy.:dontknow:
