dam you guys are payin alot, my dealer does me for $76 without me going and getting my own oil:dontknow:
They must like me or somethin
Or they may be topping you off with the brand of oil that just says (OIL) on the can..:marchmellow: :marchmellow:GotRidOfTheHemiForThis said:dam you guys are payin alot, my dealer does me for $76 without me going and getting my own oil:dontknow:
Chuck B said:The factory scissor jack actually works well,however,never ever crawl up under a vehicle without stands.
venom 1 said:Or they may be topping you off with the brand of oil that just says (OIL) on the can..:marchmellow: :marchmellow:
Here's an update for ya, Chrysler's contract with Mobil is over, they are beginning to swich to Shell Which means Mobil will begin to cost more through the dealership I just had mine changed 2 days ago, I got a hook up, but it will be selling for more like 11-12 bucks here per quart before long. So my advice is if you aren't gonna watch em, they will put Pennzoil in your motor So bring your own oil:dontknow:GotRidOfTheHemiForThis said:dam you guys are payin alot, my dealer does me for $76 without me going and getting my own oil:dontknow:
Looks like Im gonna buy the oil, have them replace the lines under warranty and do the oil when their done..I just hate taking my truck to the dealership for anything if you know what Im saying..Last time I had my 01 off road ram there they charged me for a new drive shaft, they said it was bent I had bad vibration coming from the rear end..Turned out it was the pinion bearing and diff that needed replaced..I didnt even make it out of the parking lot w/ the new drive shaft when I noticed the same sound coming from the rear end 600$ later...I pulled a 180 in the dealership parking lot smoking the shit out of the tires...You should of seen the look on a couple of the salesman's faces that were with customers out in their lot, went back into the dealership steaming and they ended up totally overhauling the rearend and leaving the shiny new driveshaft on my truck, all yeah, and the diff, and all the bearing were all covered under warranty, go figure..That's just one good reason I hate dealing w/ those people..thx for listeningFastRam said:Go buy the oil and take it with you when you have them replace the lines. If I am not mistaken, they will need to drain the oil in order to replace them. If you have $$$ and depending on your warranty situation, I would consider Stinkers lines. Oh and the oil filter at my dealer was something like 5 or 6 bucks. I take my own oil and they charged around $15, including the filter.
robjon96 said:jacks, jacks stands, ramps? just slither under there! thats what i do...
venom 1 said:Looks like Im gonna buy the oil, have them replace the lines under warranty and do the oil when their done..I just hate taking my truck to the dealership for anything if you know what Im saying..Last time I had my 01 off road ram there they charged me for a new drive shaft, they said it was bent I had bad vibration coming from the rear end..Turned out it was the pinion bearing and diff that needed replaced..I didnt even make it out of the parking lot w/ the new drive shaft when I noticed the same sound coming from the rear end 600$ later...I pulled a 180 in the dealership parking lot smoking the shit out of the tires...You should of seen the look on a couple of the salesman's faces that were with customers out in their lot, went back into the dealership steaming and they ended up totally overhauling the rearend and leaving the shiny new driveshaft on my truck, all yeah, and the diff, and all the bearing were all covered under warranty, go figure..That's just one good reason I hate dealing w/ those people..thx for listening
Prof said:You damed flat bellied limber backs!
I can get down and get under there...but it takes an hour to get back up!
Pretyflywiteguy said:$130 for an oil change? you guys are insane..
Are you lowered, hell I will give it a shot in the spring and see if my fat arsss can fitrobjon96 said:jacks, jacks stands, ramps? just slither under there! thats what i do...
GADodgetech said:My parts guys charge like $10 bucks a quart for mobil 1. I laughed my ass off when I heard what they charged. I explained to them that I could go to advance and buy it for $6 bucks a quart. I recommend buying your own oil and just pay the $12 bucks for labor. Its worth it.
