Did dodge screw up my engine?
BLWNSRT
Member
So I've been having low horsepower problem since I got my truck. With the roe I am down about 75-100rwhp max I've made was 507. I started pulling the engine apart and seen no ridge and a nice crosshatch still visible, and decided to measure the bore see if anything has been done I double checked with 2 different tools and my bore on the passenger side is 4.018" +/- .002 :dontknow:
Had anyone ran into this?
Does this make any sense?
Was this a 2006 truck change cause I've seen a few dyno numbers that were really low compared to the 04-05.
When I get the short block pulled out and sent to the machine shop i will get this looked at to verify.
JTS VENOM PERFORMANCE said:
never have, but got an 06 here, will yank a head off morrow an check it
Thanks Tony
let me change that, I was gone all weekend, just got in a bit ago tomorrow might be a bitch, but will get a head off asap to check for ya, but may be late tomorrow:eek:
not a problem I've got to get the other head off tomorrow too then find the 1 of the stage-8 E clips I lost somewhere in the garage/frame heard it land somewhere.
You be careful "yanking" that head off mister. ;)
Your truck should have been 550-580rwhp easily with your mods on 5.6lb pulley:dontknow: My 04' put down 504 with no tune and not meth added.
I'm sure you've been pulling your hair trying to figure it out:( Hope you can get it figured out. I'd hate to see you spend 10k on an engine and put down 520rwhp:eek:
TNVIPER said:
An 06 will pull as much HP as 04/05....My truck put down 680HP with a 10lb pulley and conservative tune..
I meant to say stock I know mine was low and so was Oldcolt's. But I know when they are built they are good Sean has built 2 the same setup I'm doing they both pulled 714/715rwhp and 755rwtq
I wish I had the answer. Mine just goes flat above 5200rpm. We are looking at a couple of things, hopefully we find the problem.
68....did you ever dyno your truck?
no i never did when i do i'll let you guys know but it's probably just the black ones that are a little low:hmmmm:
Dean told me you took him for a ride. He wanted to know if my truck sounded like yours!!:D :D :D
Ram.....how did your truck feel before you put the supercharged on it? Did you have any issues with the ECM or other electronics?
It ran good before hand, ran a best time of 13.9 stock here.
ust got the other head off today, Minor carbon buildup on pistons and combustion chambers no issues yet. Gonna get one more tool to measure just to verify the bores. Only # 1 & 3 measured 4.030 the rest were .012 smaller.
thats one reason we allways go at least a half overbore, alot of times we find them out fo round also, taking mine off in a minute, gotta eat this sammich first , larry and jr made me hungry:D
all the ones on this one measure from 4.26 to about 4.020 give or take buddy, seems dodge doesnt get too aweful precise as the years go along:eek:
Wow, Crappy pistons thrown into an engine.
