DenOfThievz said:From Truck Trend:
http://www.trucktrend.com/roadtests/pickup/163_0510_2006_dodge_ram_1500/srt10_comparison.html
"The SRT10 also gets the new hydroformed, fully boxed frame, and, with it, changes to the suspension.
While the overall layout of the front suspension is the same as the 2005, there were modifications to its components. In addition to all of the Ram 1500's suspension changes, the SRT10 has larger rubber lower control-arm bushings, tuned for lateral and vertical compliance.
The lowering springs, unique to the SRT10, receive new spring rates for 2006 and the Bilstein shocks were retuned.
The front anti-roll bar is thicker, going from 33mm to 38. In the rear, the geometry remains the same, but those shocks also were retuned, and there is a new lowering suspension with a power-hop control system (for the Regular Cab), which comes with snubber springs and an anti-windup monotube shock.
The Regular Cab receives a 23mm anti-roll bar in back, while the Quad Cab does not.--A.H."
DenOfThievz said:Is the anti-hop monotube shock new, or is that also existing?
What he's saying is new:
Front:
- thicker anti-roll bar (38mm vs 33)
- new front lowering spring rates
- re-tuned bilstein shocks
Rear:
- lowering suspension (powerhop control sys = monotube shock & snubbers)
DenOfThievz said:Yup - existing since 2004 according to a photo I just saw too.
Who knows what is new then...doesn't Dodge even say there were supposed to be suspension changes?
Silverback said:I would be surprised if Dodge made any changes beyond the cosmetic changes that were carried over to the entire truck line. They still had a bunch of 05's that had not sold. Would not have made much sense to invest in other changes for such a limited production run of 06's.
I assume you are referencing the SRT-10 Regular Cab and not the standard 1500.bucke77 said:my parts catalog shows the same spring from 04-06 for the RC.
turbo_neon said:I know that the pass. seat shakes when i go over bumps when no ones in it! .
mopar_mudder said:This was right from the SRT Team in a chat session.
"The 2006 Ram SRT-10 front springs (both Std. and Quad) are stiffer by approx. 20-30% and the check heights are taller by 1/2 inch to specifically address the '06 chassis geometry improvements."
That should pretty much answer all questions
mauiSRT/10 said:My passenger side seat belt knocks off the side of the truck and makes this rattle noise that drives me insane! I absolutly hate rattles! Is your seat actually moving around or could it be the same as mine? (I have noticed when somebody is seating in that seat, the seatbelt does not rattle.)
patrick
Begood said:Thre only rattle I get is between my ears.
Bill.
