Does your truck use oil?..
How many miles to a QT of oil?..
  • 500 or less..
    Votes: 3 5.9%
  • 501 to 1000
    Votes: 8 15.7%
  • 1001 to 1500
    Votes: 5 9.8%
  • 1500+
    Votes: 35 68.6%
  • Total voters
    51
  • Poll closed .
i still use a little bit of oil.. i'm due for an oil change and ithink i sucked down 3qts.. but the trucks never driven easy lol
no oil consumption here.
change every 3.000 miles + filter.
my silver qc never used oil between oil changes. the one now doesnt use a drop but its on jackstands(looks like its at a chop shop)
Larry mine did, not so much as the ring seating( didnt have blow by) mine was I beleive the lines. But I went 20w50 and have not lost any oil yet?
Hmmm...When my engine quit using oil was when I tried 20w50....after the change it used a QT the first 400 miles, another QT at 800 miles then none during the next 1300.
I used 10/40 the last oil change using the rationale that it would be better to use thinner oil during the winter months. I have driven 300 miles on the 10w40 and still is on the full mark...
What 20w50 did you use? maybe that helped seat the rings better? I know my temps barely hit 185 now (well before the 45degs hit):D
I use Royal Purple.........my temps had also started staying below 185 a couple month ago...before the temp stayed 190-195...I had assumed maybe the 69LB injectors were the cause but I had changed the oil to the 20w50 about the same time so maybe that was the cause?..:dontknow: ....though still staying down with the 10w40..
Like someone mentioned. Use non-syn oil for break-in period.
