AMS3
My glass keeps popping out of the track, and it's a real pain in the ass to re-seat it by myself. Does anyone know if the 2005 Dodge Ram 1500 QC regulator will work on the SRT10?
It should as I can't see Mopar using anything different.My glass keeps popping out of the track, and it's a real pain in the ass to re-seat it by myself. Does anyone know if the 2005 Dodge Ram 1500 QC regulator will work on the SRT10?
The retainers are brittle and don't hold. I have 98K on the truck now, and that window goes down whenever I'm driving, unless it's freezing outside. I enjoy the 110 mph AC that the open window provides. Thanks for the input everyone!I would think so since the doors weren’t part of the transformation into a 10 except the add on body panels ..
Any idea why it the glass wont stay in place ? A missing retainer or something ?
I use to use the old match book wedge between the widow and the door frame in my first Duster till I finally replace the damn thing ,, it was a pain replacing the regulator ..The retainers are brittle and don't hold. I have 98K on the truck now, and that window goes down whenever I'm driving, unless it's freezing outside. I enjoy the 110 mph AC that the open window provides. Thanks for the input everyone!
Did you ever wonder or check that is if you search same parts using Ram SRT10 compared to the Ram 1500 and see if prices are different between them ?Reg will be standard Ram 1500. Nothing go fast about doors, except the plastic bottom bit.
Rockauto have plenty to choose from
If you look on your build sheet it itemises the parts that are SRT-10Did you ever wonder or check that is if you search same parts using Ram SRT10 compared to the Ram 1500 and see if prices are different between them ?
My thought was unscrupulous venders trying to capitalize on the SRT partIf you look on your build sheet it itemises the parts that are SRT-10
I’m think it just shows what the difference between the standard ram parts and what are the adds making a SRT10 .. NOT A PARTS NUMBER LIST !Kiwi SRT10 - what do you mean by “If you look on your build sheet it itemises the parts that are SRT-10”?
I think I have a build sheet, but it doesn’t list part numbers, just the dealer codes. Do tell how you get the build sheet you’re describing.
Thanks…
Yes self explanatory!They didn't actually change that much to make the SRT-10
Equipment Listing
VIN 3D7HA16H14G170216
Vehicle Description 2004 DODGE RAM 1500 REG. CAB PICKUP
Monotone Paint
136 Amp Alternator
Front Height Adjust Shoulder Belts
Passenger Air Bag On/Off Switch
Next Gen Multistage Front Air Bags**
Floor Covering Carpet
Passenger Assist Handle
Behind the Seat Storage / Bin
Tinted Glass Windows
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
Remote Keyless Entry
Dash Liner Insulation
Floor Tunnel Insulation
Route 77 - UP, Mesquite, TX
Instrument Cluster w/Tach
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Glove Box Lamp
STANDARD EQUIPMENT
Halogen Headlamps
Cargo Lamp
Front License Plate Bracket
Dodge Badge
Removable Tailgate w/Caliper Latches
26 Gallon Fuel Tank
Speed Control
Black Clear Coat
Tilt Steering Column
Tire Carrier Winch
Pickup Box
Trailer Tow w/4-Pin Connector Wiring
Build To U.S. Mkt. Specifications
GVW Rating - 6750#
U.S. Dealer Retail
Zone 63-Dallas
Two Wheel Drive (2WD)/(4X2)
6 FT. Cargo Box
Regular Cab
1500 Series
DR-Vehicle Family
Vehicle Order Tracking
U.S. Specifications Label
Texas Ship to State Code
Texas Sold to State Code
Leather Seats w/Perforated Suede
Dark Slate Gray
OPTIONAL EQUIPMENT
Light Group
SRT Group
Security Group
8.3L Eng(EWC)/6Spd M/T (DEC)
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Perf Brakes
40/20/40 Split Bench Seat
Front Floor Mats
Front Center Seat Cushion Storage
O/Head Console w/Trip Computer/UGDO
All Manual Transmissions
6-Speed Manual TREMEC Transmission
4.10 Rear Axle Ratio
200MM Rear Axle
Anti-Spin Differential Rear Axle
8.3L V10 SFI Engine
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
All Vehicles W/Power Mirrors
Satin Silver Lock Knobs
Sentry Key Theft Deterrent System
Air Cond'ing w/Dual Zone Temp Cntrl
Instr. Panel Sport Bezel
160 MPH Primary Speedometer
Black Clear Coat - Molding - Sill
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Fog Lamps
Security Alarm
Body Color Grille
Hood Power Bulge
Body Color Front Fascia
Body Color Rear Fascia
Ram SRT10 Badge
SRT10 Badge
Viper Powered Badge
Rear Bodycolor Spoiler
50 State Emissions
Federal HDV1, Cal. MDV 1 ULEV II
Bright Exhaust Tip
Dual Rear Exhaust w/Bright Tips
Maximum Duty Engine Cooling
Black Clear Coat
All Radio Equipped Vehicles
AM/FM CD 6-Disc Radio
8 Infinity Speakers w/Subwoofer
Fixed Long Mast Antenna
508 Watt Amplifier
Steering Wheel Mounted Audio Ctrls
Performance Steering
Leather Wrapped Steering Wheel
Front Perf Tuned Shock Absorbers
Rear Perf Tuned Shock Absorbers
Rear Perf Tuned Stabilizer Bar
Front Perf Tuned Stabilizer Bar
Compact Spare Tire
P285/40R22 BSW All Season Tires
Pirelli Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
22X10.0 Aluminum Polished Wheels
Power Adjustable Pedals
Bright Pedals
Hurst Shifter
Basic Owner's Manual
Manuf Statement of Origin
2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAMR TRACKING: 30910M09AA MY:2004
FAMR TRACKING: 204SRT01AS MY:2004
Customer Preferred Package 2TS
Customer Preferred Package 29S
Distribution Services Tracking
Waterbase Paint
BusinessLink Inventory
Paint Order Code
That should cover it. So if you need to know what parts are special for our trucks, that is the option list. The rest of the truck is a standard Ram 1500 which is great for getting parts
