OK Guys and Gals,
After my last Fiasco with the truck on the Dynamometer (I was a Virgin) I am thinking about doing it again. Taking what I learned the first time so I can get it right and get accurate numbers.
Last time I only went for the HP numbers. Do I want to have the Air/Fuel/Temp readings as well? (I think they would be helpful later on If and When I start the Modifications)
I have heard a lot about Dynamometers and that the numbers generated can vary greatly between name brand of Manufacturers. I have gone to many websites and looked at more systems than I really wanted to. Each name brand “Claims†their numbers are correct and their produce is more accurate then their competitors.
I understand that this is 99.9 percent BS and is “Sales Hypeâ€.
From what I have read and what has been posted on threads here, I understand that there are as many ways to compute HP as there are companies that produce Dynamometers.
Obviously, Age, Maintenance and Servicing (both hardware and software) of the system play greatly into the equation. Given that all are equally maintained and correctly serviced….
Which is the BEST way to read HP? (other than with my ass)
This will direct me to which of the manufactures competing in that field. After knowing who the players are I can then research as to who actually makes the Most Accurate. That will lead me to the best shop in my general area that has the correct equipment and technicians to perform the Dynamometer Test/Pull.
Last Question: What Questions/Variables did I forget so I can get it done right?
ALL COMMENTS WELCOMED!!!!!
