Da1Chief said:Brand name of the Dyno is "Dyno Dynamics" it is a Mustang Style Dyno..
Yea, the guy was impressed that it made that power running that rich. He started to hint about a performance tune until I told him that would be a DC or Roe only mission...![]()
rottenronnie said:We have a Dyno Dynamics here. It's a VERY stingy unit and it's hard to get big numbers on it.
Da1Chief said:So with it being Stingy, I should consider these "Safe" numbers to start with?
Da1Chief said:Ok, I am officially Happy !!!! Thanks for the compliment guys..
BTW I am EXTREAMLY Honored that I got your 1000th Post...![]()
Now when I get a few dollars... The CAI, Cat-Back and DC Tune. Then when I win the Lottery Long Tube Headers, High Flow Cats and Mids. Trany Upgrade Kit would also be nice to put on the list.
I already have the Printout in my truck's Baby Book (3 Ring Binder with every bit of maint I have had done to it)
rottenronnie said:Chief- Would you mind asking him what ramp up rate and load he was using for your pulls? For example, I have my ramp rate at 12 under a heavy load when I do mine. Just curious...
B.T.W. Dyno Dynamic dynos are reported to be "a standard" 15% LOWER than a Dynojet when reading through many Internet posts.
that's comforting....fo sho!Da1Chief said:He did this on his own without me needing to say a word or make a suggestion...![]()
FlyingLow said:Just so you guys know I have had several pulls on that same dyno. The shop Chief went to are the people that installed my turbo. They have done dyno runs for me and Jrgnd. On the same dyno my numbers were:
Stage 1 flash 420 RWHP and 460 TRQ
Stage 2 flash 438 RWHP and 500 TRQ
Chiefs numbers are very high for a stock QC. I would even wonder if there was a flash already installed and not known. But with those high of numbers on stock I would only go to Roe for a SCT.
Da1Chief said:I will be working about a block from there tomorrow. I will be happy to drop by and ask him the ramp rate...
Did you notice that the graph shows he did the Pull exactly as you described..
Disconnected the Cable, Pressed the Tow/Haul Button, RPMs at 3600-3800, Flipped the Switch and Dropped the Hammer.....
