EED-David
If you'd like to order a breather kit, you'll need to call Kevin @ 951.545.8223. All the kits are currently built one off to order.
BigBlackQC said:Damn, 540rwhp on a QC.... that's around 650-675 out of the motor.... is it still stock displacement?
RedRamRules said:You mention in the General information: "The customer was dead set on a “stroker” engine which in hind sight I would have probably pushed them away from the stroker crank in favor of a shorter stroke / higher revving package with larger bore size. These engines are short deck with an unfavorable rod ratio to begin with, so stroking the engine really isn’t the way to go."
Does this mean that for a N/A application (In my case I don't plan on adding force induction), that adding more cubic inches isn't a good move due to the engine design? Would it be more recommended to upgrade to stronger internals & a better head package? Thanks.
Bone said:I too would like to see some prices (heads plus valve covers/spaces).
Thanks for the quote. About the same price as a SC.EED-David said:Striker heads are $6600, valve cover spacers are about $600.
