Electric fan ??
scottstoy
Arkansas
Do electric fans work, and if used do you disable the stock fan?
Yes e-fans do work and it is up to you if you want to disable the stock fan or not. Question is why are you trying to get rid of it? They are VERY efficient at cooling the engine. The PCM can be flashed to have it turn on sooner if you would like.....
I have had 3 pumps put on and replaced the high px hose on top each time, i finally went to a radiator shop, who made me a line better than stock, but its begining to leak now, plus on real hard turns the power steering stops working for a second.
Then go ahead and pull that sucker. I would get the SPAL fans with their PWM controller. Help the fan(s) last a lot longer. Then you can still turn the on manually for times at the track.....
scott, trying to figure one up now, but the diesals, they have aftermarket fan set ups that work great and should fit, and with shrouds, but problem is they arent too cheap for a good set up:eek:
but you can look up like bd diesal, becool and companies like that that have them
Thats awsome, thank you very much, is it stinker or what do you go by,.. I have read these forums for years just never bothered to sign up but i am glad i did now you all seem like a great group of guys..:rock:
LOLOLOL well depends on to whom you speak with :D
some call me Stinker, may actuall name is Tony of the Sawyer clan:D some call me butthead, LOLOl and some call me much worse at times:p
LOLOL ya gotta watch these fellas too , they will give you the number to time/temp in singapore and tell you its my number:D
LOL well its a pleasure to meet you Tony, are you always at your shop? I will be calling you soon for some stuff im just saving up now. Its time to do some remodeling and upgrades.
LOL well yes and no, but usually from say 11 am til about 2am eastern time bud.
weekends a lil tougher, trying to stay away from sundays and give momma some time with me:D
but anytime give me a shout 704-214-7849
i hope to have the site going alot better soon, so that most of the things can at least be seen there.
but as long as ya speak or understand southern redneck english we'll do jsut fine:D
Be careful if you switch to the diesel fan as it is driven off of the water pump, and the diesel motor doesn't ever spin 6000 rpm. I'm not sure that the diesel fan would like that.
