FS: Forced Induction SRT10 Partout, OEM parts and Engine parts
JMB Justin
Preferred Vendor
Hillsboro MO
Ive added a ton of pics since my other thread and updated the list. Without being able to edit the first post, these for sale ads get messy quickly.
All parts in great condition but used, prices do not include shipping:
-Suede covered headliner and door sill set, very nice $150
-Candy red Line lock bracket and lines $30
-Single nozzle Nitrous express kit with big carbon solenoids, MSD 8969 window switch, and brand new never used bottle $375
-VEC3 $200
-VEC low impedence injector driver $40
-Water injection pump and Roe control box $60
-Electric fan adjustable temp switch $15
-OEM 03/04 crank, all stock journals $450
-Big Rotor/High volume/pressure oil pump and front cover assembly $450
-JMB Hidden Coolant overflow jug $40
-Diamond pistons, one bad, 4.040 bore, .927 pin, 8.8 Comp $100
-JMB Candy red radiator fan shroud $100
-OEM radiator $300
-Stock fuel rails modified with -6 ends on them for a aftermarket fuel system.
Powdercoated reflective chrome, never installed since modified/coated $175
-170 Tstat $20
-Candy Blue Gen 2 valve covers (clear aftermarket rockers on Gen3), no
core, new powdercoat, never installed since coating $350
-Candy red T-stat housing with swap for your stock $30, $130 outright
-Corbeau seat belts $20
-Torque limiter setup, worked great even with huge power $75
Most parts in the first pic are "make offer", im selling cheap.
Most of the OEM stuff on ebay, under seller "mopar211" most starting at a $1!!
Updated list, a bunch of oem stuff is selling cheap on ebay too!
-VEC3 $200
-OEM radiator $300
-170 Tstat $20
-Corbeau seat belt $20
Between the crossmember and the engine mount. It prevents the motor from twisting up.
-Single nozzle Nitrous express kit with big carbon solenoids, MSD 8969 window switch, no bottle or feed line $250
-VEC3 $200
-OEM radiator $300
-170 Tstat $20
