Marc T
NZ440R/T said:Thanks D, good advice and input. Of course, I'm not one to believe until I try so I was always going to drive the truck before I even considering opening my wallet for a new clutch, I will see, but, your post & comments give me good confidence that I can leave the clutch as a stock set up. Also, I will be leaving my truck it's stock 500hp @ the fly, may get an exhaust and little things but that's it. What mods have you got to get 600rwhp?
About the hydraulics. Is there just the 1 kit for the upgrade? Or are their several, what does everyone use and do you have a part number for the kit? I will get them to do it when they do a RHD conversion (mandatory in NZ).
Cheers,
Carl
:rock:
Carl,
Centerforce has been tried and proven in these trucks, I have over 30,000 miles on mine with the last 5000 miles with the SC and have had no problems. I also have the Viper Hydraulics upgrade which is a must.
There are other clutches out there but most of them have grenaded or burnt up! I believe the ACT clutch is showing positive results. The Cenerforce has been out since 2004 and has been installed and tested more than any of the others.
Break in will be another key issue! I drove mine for 750 miles in breakin mode before hammering it!
Good luck, and hope you get your truck soon!!:rock:
