I've always wondered why someone didn't just bolt on an 8-71 and call it a day. Assumed the answer was because it was easier, and just as effective, to bolt on the pro charger.
Won't fit under the cowl....
How much taller could it be than a roe?
? Haven't looked at a roe truck in a while but there wasn't much room
6-71=411 cubic inches, roe(whipple/lyshlom)=3.3/3.4L or 207 cubic inches, so yeah about half the size but I think they spin way faster
Any info on how much the liquid cooled blower helped intake temps
Yup, the gmc blowers are ancient technology. But still look bitchinBut I believe they compress the air in different ways which makes the difference in size not the whole story
I'll ask the owner of the truck and post it up
That's exactly what I would like to do, but haven't found anyone to make some pullies.
Cool, was he still running a heat exchanger under the blower too?
How bad is your belt slippage? How much boost are you running. Are you running all the stock pullies.
I gave it a quick google and there a few people running cogged set ups on the Paxton novi 2000 charger. Would running a cogged set up cause any stress on the crank?
Im running a 7" crank pulley and the rest are stock and 8PSI boost,I have the Blown Away blower brackets that are almost twice as thick as the stock Paxton brackets and theres an adjustable belt tensioner (that doesnt do much,being that its slot to tighten isnt on the proper angle,the pulley will push the belts together and touch before the end of the slot)
I keep throwing belts,Ive tried a bunch of different belts and they all get eaten up and eventually tossed off,wrecked 6 belts last summer,its when im torqued up and the truck moves sideways as I let off is when it throws it off and eats it up!
Sounds like something out of alignment, my buddys 280z used to do that too but only at high rpm, would drive around all week just fine then chunk the belt first pass at the dragstrip
