Group buy Raptor shift lights.
MUTT said:
bump again...still need 5 people:D
FSTJACK = 1 Blue
MUTT = 1 Red
mmmmtorque = 1 blue
JRSVIPR = 1 Red
FastSRT19 = 1 blue
kyle's srt10 = 1 blue
Stinker said:
guys this is one of the easiest mods you will do!
Simple installation, and better track times!!
Plus it just looks cool as hell!! Especially when it does its thing when ya turn the key!!:rock: :rock:
Cmon guys you want get a better deal on a shift light than this:rock:
Can someone post a few pics of this unit along with install instructions/pics. I don't want to get into something way over my head. If it's REALLY easy, I might jump on one. Thanks!
:hmmmm: :hmmmm:
:hmmmm: :hmmmm:
A beginner can install one in less than 2 hours. Maybe VnmPwrd will chime in on some pics of the install we did for him.
The switched power source came from circuit F984 pink/yellow at connector C220 pin #14 under the dash to the left of the clutch pedal. Ground just went to an IP brace.
The tach signal can be picked up at the PCM located in the passenger rear of the engine compartment. There are 5 different coil driver circuits that can be used all located in the black PCM connector C1 (the bottom connector). Any one of these can be used...
Pin #1 is circuit K133 dark blue/white for coil control #4
Pin #3 is circuit K18 dark blue/orange for coil control #3
Pin #5 is circuit K134 dark blue/yellow for coil control #5
Pin #7 is circuit K19 dark blue/dark green for coil control #1
Pin #9 is circuit K17 dark blue/tan for coil control
AARHEMI said:
can it be hook up to a hemi if so i,d be in for a blue
I'm pretty sure it can. Install should be very similar to the SRT-10 install. The tach pickup will be different. The Raptor itself can be setup to run on just about anything. Here is their website. It will run on 1 to 12 cylinders.
http://www.raptorperformance.com/index.html
MUTT said:
bump again...still need 4 more people:D
FSTJACK = 1 Blue
MUTT = 1 Red
mmmmtorque = 1 blue
JRSVIPR = 1 Red
FastSRT19 = 1 blue
FSTJACK = 1 Blue
MUTT = 1 Red
mmmmtorque = 1 blue
JRSVIPR = 1 Red
FastSRT19 = 1 blue
Voodoo = 1 red
was going to get it done this week when i was at home but damn if i just did not get the time to do it. soon, very very soon
FSTJACK = 1 Blue
MUTT = 1 Red
mmmmtorque = 1 blue
JRSVIPR = 1 Red
FastSRT19 = 1 blue
QUICKSRT10/SRT8 = blue
only 3 more needed!
put me down for a blue one
FSTJACK = 1 Blue
MUTT = 1 Red
mmmmtorque = 1 blue
JRSVIPR = 1 Red
FastSRT19 = 1 blue
Mjpmattox = 1 blue
Put me down for 1- Blue
Hi
