H/U Question
ViperCLKGTR
I didn't wanna hi-jack Drumlines post but has anyone tried to drop the newer MOPAR NAV units from the SUVs/Trucks/Vans into an '06? I have a guy wanting to trade mine for his. It has the same steering wheel controls and is equipped with UConnect? Do you guys think it would work?
I have several customers that have swapped Mygig radio's into their 06-08 Rams. It is very time consuming but worth it according to them.
What would be involved in that swap?
Lots of solder and heat shrink! :D You also have to ensure you get the proper bus speed Mygig. If you get the wrong one it won't even turn on.
So I better leave it to a pro if I do.
Do they retain steering wheel and UConnect capabilities?
What is bus speed and how would I figure that out?
Mygig in an 06 is not that hard. You need......
Early Mygig RER (Low Speed Bus 07-10)
NAVIGATION RECEIVERS : OEM Auto Parts
A Filler piece for the dash..
Mygig Factory Navigation Adapter Lockpick Retro Fit Bezel Filler | eBay
Lockpic form Coastal Electric MYGIG ADAPTER
Or
Coastal Elec Mygig Lockpick Upgrade Radio to A Mygig Radio Adapter | eBay
You will also need a GPS antenna if one does not come with the unit you buy.
And if you want U-Connect throgh the mirror...This Cable
Chrysler Dodge RAM Jeep RER Nav Radio Uconnect Mirror Wiring Harness Mopar | eBay
And a new mirror.....
RAM Dodge Chrysler Jeep Uconnect Microphone Mygig Rear Mirror RER RHR Mopar | eBay
Or if you don't want to change the mirror you can use this cable & mic...
Chrysler Jeep Dodge RAM RER Uconnect Microphone Kit by Mopar 82211743AB | eBay
And if you do not have a NAV (REC) in the truck now you will need a new Bezel for the dash also ($100-$500)
And the steering wheel controls still work.
Hope that helps.
Or
Hope that helps.
Thanks for clarifying all that was needed. :D
