head install
perk_1405
yo mamas house
i just ordered a set of ported and polished heads from Taliban Dan. they should be here tomorrow. i have to get all the gaskets and im going to install my self soon. has anyone ever done this them selves. i talked to tom sessions he is the viper tech at my local dodge shop and said it would be no prob. any tips or tricks would be appreciated. thanks and this is my first day on your forum i moved over from srt-10forum....
not too many tips or tricks on this one, just alot of beer:D and patience;) and bandaids:nurse:
Welcome to the site...you will find lots of help here...you will have more advice than you want in a couple of hours...
Enjoy...
Enjoy...
sorry PROF , but i think with that avatar you better go in offensive reply's... nooby's won't see the man behind the name.. but the looks...:p :D :D :D
Dont worry Berry Roy has a thing for young interns.:p :p :p :p
Elliot, did you see the reply from your post on the other forum?
Or just give Dan a call.
i called dan he's sending me the specs tomorrow. im going this weekend to get dynoed beffor i install the heads. i was just seeing if anyone has done the swap them selves, and knew a few things to look for.
:mad: why does it say >>>>you got a hemi?>>>> under my screen name... i cant find out how to change it, i didnt write that..help:mad: :mad:
It will go away as you post more.
Welcome to the RBC!
That lets us know that you are a newby, and we need to be gentle with you...everyone except The Sickness...he is never gentle...you will love it here.
My tips:
-Don't reuse the factory head bolts. Buy a set of ARP bolts, or I would go with a head stud (truer torque over a bolt).
-Chase the threads in the block with the appropriate tap.
-Make sure the block and the heads (gasket surface) are completely clean and free of any oil or grease.
-If using stud, do not tighten the stud into the block. Thread the stud into the block using the moly lube ARP provides and then back it off a couple turns. This process results in a truer torque on the fastener.
-I like to use copper seal on my head gaskets (also intake and exhaust). You can get it at any auto parts store. Permatex makes it and it comes in a spray can.
-Muzzy
i just got back from getting her dynoed. not to bad, 455rwhp and 497lbtq... i guess it could be better. the shop "B & T Performance" said its the highest they have seen. the last rc the had on there had 421rwhp and 469lbtq. i scaned the dyno sheet to my comp. but i dont know how to post it.
here is the dyno sheet..
