Ram From Hell
Not a bad day, since nothing broke. I'll say that much.
Didn't make nearly as much power as anticipated, but we're looking at either belt slippage or we're running out of supercharger. Boost came up to 6 PSI by 4000 RPM, then gradually sloped off to 3 PSI by 6000 RPM. With no other signs (or sounds) of the belt slipping, plus the boost dropping in nearly perfect proportion to RPM seems to point to the compressor not keeping up with the engine. Still, the tension on the belt isn't particularly good, so I have to consider that slippage may still be at least playing a part.
So, HP peaked around 4000 RPM at around 635.
I'm going to pull the front off of the truck and work out the placement of an additional pulley that I can put additional tension on the belt with, then try it again. If that doesn't do the trick...
...it's going to be turbo time.
