I bet you see quite a bit of improvement. Unfortunately, we can't see you A/F ratio, but I bet it was plenty rich, so your PCM should be a good test of what it can do for you.RAM82A1 said:Well, the results are in and they're not very good. 412 RWHP and 438 RWTQ (SAE). The pulls were done in 4th gear and I only did 3 pulls. I will change the PCM and thermostat and give it another go in a week or so. Any ideas on why so low:dontknow:
Also, they would not connect to a spark plug lead to monitor rpm, but found a coil wire under the intake. They used it instead. How did they monitor rpm for some of you guys?
Bone - they do group discounts of 10 or more. The pulls have to be set up on the weekend. For 10 or more people, it's $35 for 3 pulls.
35 bucks, heck I'll spend more in gas getting there.
Did you say what kind of dyno it is? Dynojet?
Like they said, every dyno is different and no two days are alike. Everyone on the forum will tell you that. But go to the track and you can get within .2 secs of your 1/4 time everytime (unless you are at the Mopar Nats in a RC), go figure.
