so you're saying they're the same person wanting internet fame???
someone should just look up his ip address...if they're the same...it's undoubtably the same guy???
epic fail to the guy claiming epic fail to everyone!!!I might be wrong.
I am just throwing possibilities out there....
The only way you can copy it, and paste it....and a different username than yours be in that spot....is if you erase YOUR username, and insert something else VIA editing.
I found this all too hard to believe. Just isn't likely. So I quickly did some looking into it, and immediately saw the obvious. If I am wrong, I am an Epic failure.![]()
Trying... but what is the lightning driver's Login name on here?![]()
You will need to get IP info from LightningRodder....on Stewart302..... (fat chance probably)
I don't think it is necessary. Just a quick look at his sig over there, should be proof the kid doesn't own a single digit mustang, single digit L, and a eaton/sprayed L.....
Then to boot....BLAZIE and Stewarts posts are the only posts in all of these entire theads....that are run on and on and on and on.....
New join dates.....threads posted within minutes....
I need to do some things, hopefully the epicness is greatly increased by the time I get back on. If I am wrong, so be it. The only way out of this for Stewie....is to say he edited his paste, and physically typed in "Welcome, SPAZIE".... That is the only single excuse. Copy and pastes don't vary....they are what they are. I better get my gloves ready, I think Stewue might be a little mad his cover got busted....
So y'all are saying that this guy came on here told this story to make L's seem cooler and viper owners like idiots?
