GADodgetech
Ah who??andrew heywood said:how about a backfire in the intake, that scared the s#@t outta me
You never heard one ? does not sound good , and it makes your heart jumpGADodgetech said:Ah who??
I've heard that loud ass WHOOOOSH sound then the motor dies, is that what were talking about?andrew heywood said:You never heard one ? does not sound good , and it makes your heart jump
This is origanal post. got to jawin about rev lim and rpms, then swapped a scary drivin story, thats allpokeytemplar said:I was checking out their site (once again) and I had to ask you all this question:
How in the world can they make that engine run at 5400-6300RPM continuously without the #3 throwing? I know that they are showing "at the crank" HP and TQ numbers but people have blown theirs with less. Is it still all just a matter of tuning?
Just throwing this one out there for your opinions...........
Stinker said:a 522 stroker is no different, if you want a motor that goes 7k rpms, prepare to spend inheritance and often.
Stinker said:off set grinding the crank puts the rods into a different angle thru the bore, it has been done and alot
but there actually is no gain in hp, just bragging rights of cubic inches, you will gain a touch of trq, but hp usually there isnt much difference,
your best bet is to resleave the block and go with a larger bore to get more cubes.. there fore more hp.
let me state something tonight, here , and now, i am not an expert on viper engines , that takes years and years of experince to do, but i am wanting to get into the building of them, and with that for the past 6 months have done a ton of homework.
going with a 522 does give you more cubes, but not neccessarily more hp.
one can actually make jsut as much on 505 cubes
for years some builders have used the 522 deal as a way of mking tons more $ when actually it dont take not that much more to do a 522, jsuta little more machinging
Stinker said:eagel makes a 6.123 rod which isnt really a viper sized rod, it si the same as others, the crank has to be machined to match, and the pin size is .927, they just used the rods size from a 340-360 mopar.
oliver rods with are the choice of major builders run $1850,
i dont even mess with carrillo, there rods are way too over priced and you get the same quality for 1k less with oliver or even dyers
HEY JT , thank you kindly:congrats: I will keep it under 55 ,5400 is plenty fast to do sum asswaxin:rock:Stinker said:I'm a little tired and hungover so this is short and blunt so excuse me
going past 6000 rpms is jsut dumb, peak hp on a heavily modded motor stops at 5800rpms and thats a heavily modded motor, there are some that go to 7000 rpms but youare talking a 60k motor, total with stud girdles, finely matched pistons, 2k rods, and a ton other stuff, but........they dont live long, they are built for one reason and one reason only........a pass at atime.
9 out of 10 motors on this forum quit making hp at 5400rpms, you risk major breakdown and valve float after that.
even with a good set of aftermarket springs please dont go past 6300rpms , and then you are jsut waisting rpms:argh: so why do it?
jsut because it sounds cool? anything that turns up that high is made purposly for short stretches and it takes a ton of money.
