mopower1958
- Joined
- May 20, 2006
- Messages
- 2,482
- Reaction score
- 0
JMB Justin said:They are ready to go!
Mopower, I will get with my dad and see what he says on those,
Justin
Any word from your dad Justin?
Justin
TNVIPER said:Hey Justin..when do you think the sway bar links will ship?
kyle's srt10 said:Thanks justin:rock:
JMB Justin said:They went out today, I was waiting on new front ones to arrive since im short on cores at the moment.
Justin
TNVIPER said:Justin is the plastic slave cylinder and master cylinder included in this sale?
mauiSRT/10 said:Justin, tell me about these endlinks. What can I expect from installing them? I read your writeups from your website.......is there anything else you can expand on? How difficult is the install?
patrick
JMB Justin said:Sorry, yes we should be able to do them, heres our color chart, the reflective chrome with clear is probably what your looking for:
http://www.jmbperformance.com/colorchart.html
Justin
JMB Justin said:They all use the same style pumps, the progressive setups from DO use a trick controller that can be dash mounted and changed at will. It has a turn on point and max point, so you can ramp the W/I in instead of just pounding it all at once. To use it on an SRT requires a GM 2 bar map sensor since our factory map sensors are a 1 bar and dont read boost. I have the sensor and pigtail in stock, or you can get one from the local dealer. They run $65 for the sensor and pigtail. You can use your washer jug or there are other tanks available seperately. I have used this kit on a ton of SRT-4's, even on one making 560WHP (2.4L 4 banger), with zero issues. A buddy of mine has used probably 5-6 kits on TT vipers (making 900+), procharged LS1's and terminator cobras with excellent results as well. If you have a VEC2-3 I would recommend the Roe kit instead because you can run it through the VEC to progressively control it (I also sell the Roe kit) instead of having to buy the map sensor setup.
Justin
