Nowwhat said:JDMs.....on ebay.....like $140.00 with shipping I think.....you will see them on there....the quality is the same as OE....
ViperTruck2933 said:Looking great mang!!!
Another thing I did was put in some Silverstar turn signal bulbs that are silver/clear when they are off but they still light up amber. Only cost a few bucks at Autozone and you don't see the yellow when they are off.:rock:
Install on the headlights and bulbs is a breeze.
Rice Eater said:Nowwhat...thanks for the info...i did the same thing to my magnum RT.
What kind of middle grill do you have? I am looking for a black one like yours but all i can find is the Honeycomb...but yours looks like the pattern matches the lower grill?? Looks good!
Why are you guys amped up on cutting out the hoodscoop grill? What did the rubber molding accomplish? Just curious!
I did the same mod myself. I used a box-cutter knofe to remove the plastic tabs after you remove the hood grill, then used a dremel to remove the leftover tab material. I got some door molding material (The kind you would use so that you don't ding the door edges) from Kragen and put it on. I should post pics. BTW I did it almost immediatly after seeing MIke's truck in person. Thanks for the inspiration mang!:rock:Rice Eater said:Nowwhat...thanks for the info...i did the same thing to my magnum RT.
Rice Eater said:Are these them?? I think I am going to get them!
http://cgi.ebay.com/ebaymotors/02-0...hZ019QQitemZ8072876923QQrdZ1QQsspagenameZWDVW
Nowwhat said:The black headlights with clear corners that Vipertruck2933 has are just sick...soo...on to ebay and presto....
Thanks VT
ViperTruck2933 said:Look at my sig pic. Can't really tell the OEM honeycomb is different unless you are specifically looking for it.
Texas Yellow Fever said:I agree with this, the factory honeycomb grill matches fine IMHO.
Nowwhat said:I dunno man....I bought a honeycomb grill then just threw it away......:dontknow:
Thanks VT
Thanks VT
