yellow446
Not cheep but . I think for what u get is good . U get everything with it .
I had an interesting idea!! I was woundering what kind of power could be made with a set of Striker heads,an agressive cam,Hogan intake,a good ram air intake,some good coils,wires,underdrive pullies,electric fan,electric water pump,a bump in compression and some good tuning??
What ya think???
What ya think???
Just under 1800 wheel.
It's all in the coils...
Generally speaking, forged parts are heavier than the cracked powder rods and the hypereutectic pistons used by Dodge.
K1 rods for example (if you want to use those) are 42 grams (each) heavier than the o.e.m. rods.
Ronnie
So generally , forged parts are probably heavier than OEM ! That would also means that balancing would be easier due to removing weight from the crank to offset the added forged rod and piston weight instead of having to add weight to the crank for balance procedures.
Can any engine shop balance the viper engine assembly or is there specific equipment to do this?
I live in Cali and I would like to find some one t o this
