ramv10
I recently installed slow bleed lifters and had them at 3/4 turn from 0 lash. After running the truck to pump up the lifters, i re-adjusted them to 1 turn from lash and everything was fine. Truck had been sitting for a week and i fired it up today. There was a ticking sound from the driver side head that sounded like a loose rocker. I turned the truck off and took the valve cover off and the rockers on cylinder 1 were loose. Started the truck again and all the rockers were getting oil except the ones on cylinder 1. After about 20 seconds oil started flowing from the rockers on cylinder 1 and the rockers weren't loose anymore. Push rods are seated correctly on the lifters and rocker cups. Lifters are installed with oil hole up. Why would the lifters loose oil pressure like that. Input?
