riley6 said:Whoa, that's abit much. I assume this one has hydraulics or air suspension. I was thinking maybe 1 or 2 inches lower than the typical lowering kit(s) out there.
Stinker said:basically after 2 inches in the front an 3 inches in the rear you run out o suspension travel, a arm modifactions as well as c notching the rear has to be done.
so it gets pretty expensive after a reg drop kit
that's as low as i went, any lower & your bouncing off the bumpstops like portlandsrt........Stinker said:basically after 2 inches in the front an 3 inches in the rear you run out o suspension travel, a arm modifactions as well as c notching the rear has to be done.
RC's are already run under the axle......Floor said:did you flip the rear spring or are they still above the axcle?
moparracing said:that's as low as i went, any lower & your bouncing off the bumpstops like portlandsrt........![]()
i don't have too & i'm only an inch higher than you....portlandsrt said:I RARELY hit my bumpstops... Just gotta take it slow over speedbumps and railroad tracks..
-- Hey Randy,,, thanks for the referral to Punks Muffler.. They fixed the rattle in my Magnaflow catback today...
