M&H Drag Radial Results
rottenronnie
Well-Known Member
Calgary, Alberta
This is a repost from the Racing Forum, but maybe others can post their thoughts specifically on the M&H setup...
I wish the M&Hs (390-40-17) were even taller.
With my setup, the truck doesn't like the lower tires dropping the rear ratio from 4.56 to 4.91s. It feels a bit like a mountain bike stuck in low range and mile-per-hours harder with the factory 22s.
Good 1.8 60' (1200 r.p.m. launch) with the M&Hs though, and a decent 12 second E.T. on a 5200 foot track.
The auto needs frequent band adjustments.
How do Caltracs work with the factory radials, for members using those?
My first time at the track I tried to use the stock tires and I think I ran a 16.00 1/4 mile with a horrible 60' like 3.2. Haven't ever even thought of trying stock tires after that. I do have 410s in it so it helps me using the M&H DR's.
The Caltracs work with weight transfer. The more transfer the better the Caltracs work. All we can do to improve the weight transfer other than the M&H's is the front and rear QA1's from Justin.
Change your gear ratio..... .410s w/ the 390's feels perfect...with 150 shot puts your right at 5600 in 4th through the traps. Plus you might get better MPG on the highway too
Yellow venom said:
Hey Rottenronnie did you get out to a track? If so what did you run?
Nothing too earth shattering yet. At a 5220 foot D.A. it ran a 12.87 (1.8 second 60 foot with a 1200 R.P.M. launch) at 104.85 into a 18 M.P.H. head/crosswind but the tranny wouldn't shift into high gear and the engine was bouncing off the rev limiter at around the 1100 foot mark. Right after that, it ran a 15.9 @ 83 M.P.H. and as you can tell from the stock hemi truck times, something wasn't quite right!! I had to let off a few times and then finally just coast...
The tranny goes in for repair again tomorrow. He thinks it might be a bad governor because the fluid is nice and clear. I had just tightened the bands 2 weeks ago so maybe some junk got into it; we will see here shortly.
I really need to get it to a good track (Edmonton or the Hat is 4 M.P.H. and 4 tenths quicker than we are here). But I'll let you know once I get some everything-is-working-like-it-should times. Even better- a chance to get it to a sea level track (that is tough this time of year during construction).
There should be a fairly low 12 in there without too much problem.
But for now...that's racing I guess!!!:burnout:
Ron
Thanks for the tip about the 4.10s, they should put things back on track from the 4.91s it thinks it has now.
I DON'T LIKE the "low range" the M&Hs put the truck in. The Strikers and cam choice produced a wide, relatively flat torque curve varying only 20 ft. lbs. from 3800 to 5400; that part worked out and it seems to be breathing well even without headers...but the truck doesn't want nor need the "low gear".
I am cursed right now as the stock wheels and tires are way over matched and the drag radials make it a screamer (and not in a good way).
The mileage on the highway is good and hit just over 20 (a bit bigger gallon here in Canada though), with a pen and paper calculation. Both the highway and city mileage figures rose 20% over last year, before I did the engine work over the winter.
If the truck was a track-only vehicle, I might consider a gear swap but I don't want it for the track only or I would have bought a Lightning.:D
I may have to look at a gear swap in the future though and/or pray for someone to make taller drag tires.
Ron
moparracing said:
for me, caltracs stopped the wheel hop & gave me more straight line control....... not alot of help in the traction department, though. :(
Thanks, that is what I needed to know...
I DON'T LIKE the "low range" the M&Hs put the truck in. The Strikers and cam choice produced a wide, relatively flat torque curve varying only 20 ft. lbs. from 3800 to 5400, so that part worked out well; but the truck doesn't want nor need the "low gear".
I may have to look at a gear swap or pray for taller drag tires.
Ron
i gotta agree with ya....... i was really disappointed in just a 3/10's difference in my drag radails over the stockers..... and yeah, it was screamin' @ the 1/4 too.....:(
I am hoping to get in more track time once the tranny is sorted out. What a bummer that was!!
I had the tranny modded to shift into high at redline and Chris Jensen figured the ABS sensors may have been confused as the rears are now turning quite a bit faster than the fronts and that could be keeping the tranny from shifting like it should! Well at least I know it runs high 12s under "less than ideal conditions".
If you hear anything about a taller tire setup, let me know and I will do the same.
Thanks!
Ron
Our local track is 1/8 th mile and my truck likes the lower gearing, going thru the lights in the high part of third gear.
THAT would work; especially for you with a manual transmission.
