So if i buy the metal master and slave and only that, my clutch pedal will be easier to press? Or do i have to buy a dual disc clutch too? i run a spec 3+ clutch and a clutch master cylinder, slave, trans from a gen 2 viper car.
Also i dont see any thing related to the clutch master cylinder in the srt10 ram section on JTS VP's website. I have one on Roe's site though. But those add a spacer or something which wont work with my set up. The clutch wont fully engage. not enough air gap.
Yes, you only need to change to the JTS Venom master and slave. I had the Viper system when we installed the McLeod Twin Disc (3 finger, not diaphragm) and the pedal pressure was way harder. After ruining 2 slaves and breaking the master out of the firewall, I went to the JTS V system, no other changes and the pedal pressure was reduced by almost 75%, way easier.
