Rice Eater
so if the truck is on a slight incline (jacking up the rear just enough for my fat ass to crawl under) is the fill not going to be correct amount once it comes out the fill hole since the truck on an angle?
Ok I keep reading that any name brand fully synthetic ATF is good for the t56, I also know that royal purple makes the regular synthetic ATF, and then I hear about the synchromesh, if I can only get ahold of the reg ROyal Purple syn., is that ok to fill it up with?
So I pulled out only 3.1-3.2 quarts of black sludge and replaced it with 4(-the little that I spilled) of nice fresh tranny juice! Thanks for the help!
What kind did you end up putting in?
4 quarts ,,,book says 4.8 pints ???????
SPECIFICATION
8.3L 15.1L (18 qts.)
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options.
Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary
cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 48RE 3.8 L (4.0 qts.)
Overhaul - 48RE 14-16L (29-33 pts.)
L
Service Fill - 45RFE/545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
Overhaul - 45RFE/545RFE 14-16 L (29-33 pts.)
L
L
Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or
use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC/FLUID -0 - 8 LUBRICATION & MAINTENANCE DR/DH
STANDARD PROCEDURE)
MANUAL TRANSMISSION
G56 5.67 L (12 pts.)
GETRAG 238 2.2 L (4.2 pts.)
NV5600 4.50 L (9.5 pts.)
NV4500 3.79 L (8.0 pts.)
TREMEC T-56 2.27 L (4.8 pts.) <------<------<-------<---------<----------
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205F 1.6 L (56 oz.)
9 1/4 AA 2.2 L (76 oz.)
9 1/4 AA EL 2.2 L (76 oz.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1 L (72 oz.)***
10 1/2 AA 2.5 L (85 oz.)
10 1/2 AA EL 2.5 L (85 oz.)
11 1/2 AA 3.6 L (122 oz.)
248RBI (DANA 60) 2.8 L (46 oz.)****
**** Add 147 ml (5 oz.) of Limited Slip Additive
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing
tolerance and refill procedure.
