I know we have a reusable pan gasket but does it ever need to be replaced? Last time I took it off it was fine not cut or anything frm what I remember....the bolts aren't loose but I have a steady slow leak and it drips from the bolts....the gasket stays alittle wet.....is. it possible for the trranny toleak anywhere else like from the cannon plug that goes through the tranny or something else? Since my truck isn't running and I had a drain plug installed I may just take the pan off clean it, re-adjust the bands, look around and put it back on to see if I can get it to stop leaking.....just want to know if I should be looking at anything else that the leak could be coming from while I'm there
